1992 Geo Metro
LARRY WARLAND
  • 1992 GEO METRO
Engine Performance problem
1992 Geo Metro Front Wheel Drive Manual
My Metro will randomly stall out like it is running out of fuel. Sometimes it will do it while at highway speeds and other times it will do it sitting still idling. I have done a tune up on it and have taken the fuel line off and it seems to pump a lot of fuel. Any thoughts? If your answer cures the problem I would be glad to pay something for it.
Friday, April 16th, 2010 AT 12:07 AM
Verify the fuel pressure with a gauge if okay clean out the idle air control valve and test the TPS and MAP sensors-if all are okay -test the coil, ignition control module and distributor pick up coil
Tuesday, April 20th, 2010 AT 4:55 PM
