Replaced shocks with struts
130,000 MILES
SAMUEL144
Replaced shocks with struts is there an adjustment to soften ride or just to lower or raise the car?
Jul 6, 2017 at 1:14 AM
WRENCHTECH
  • 20,760 POSTS
There is neither. The shock/strut is what it is out of the box and nothing can be changed. You should have researched which brand of shock would have been best for you before purchasing them.
The shock contributes a lot to what type of ride you get but has nothing to do with height. The only connection shocks/struts have to height is if you run a car too long with worn out shocks, it will abuse the springs and cause the car to sag. New shocks.struts will not correct that.
Jul 6, 2017 at 1:58 AM
SAMUEL144
Thank you very much it was nice with the quick response.
Jul 6, 2017 at 2:34 AM
WRENCHTECH
  • 20,760 POSTS
You are welcome.
Jul 6, 2017 at 2:44 AM
