Gears shiftlng hard, code 00453
2006 VOLKSWAGEN JETTA
170,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
06VWJETTA
My car drives fine after being started for the first time each day and I am able to drive at a consistent speed down a highway for a few hours, but as soon as I come to a stop after driving for a consistent speed for a while and begin to accelerate, the car takes a while to shift gears and doesn’t shift until the rpm's reach a higher than normal range. Once the gears do shift, they shift with a heavy jerk.
The code that the reader presents is 00453 which states that the transmission is overheating.
Jul 31, 2019 at 1:57 PM
SCGRANTURISMO
  • 4,897 POSTS
The code "00453" in a 2006 Volkswagen Jetta corresponds to a fault in the brake booster pressure sensor circuit.
If the wiring and connections are in good condition, then you may need to replace the brake booster pressure sensor itself.
Thanks,
Alex
2CarPros
Aug 1, 2019 at 8:35 PM
06VWJETTA
It’s a transmission code from a Vag-Com reader.
Aug 2, 2019 at 1:32 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, my VAG/VAS DTC list starts at 16394 and ends with 19667. Could there be a DTC number somewhere in between that corresponds with the DTC number you have given me?
Thanks,
Alex
2CarPros
Aug 2, 2019 at 2:09 AM
JOHN BRITO
This is most likely a transmission valve body. The 09G is notorious for this issue. Mine has the same problem and after extensive research I figured out this is the problem. At first, I thought it was the transmission control module but all videos and posts I saw related to the valve body described my issue to a Tee!
May 31, 2023 at 3:17 PM
  • 110,244 POSTS
Hi:
Thank you for that information. I know it will help others.
Feel free to return anytime.
joe
Jun 2, 2023 at 3:21 PM
