there is vibration and shaking when car reaches certain speeds
2007 DODGE NITRO
143,750 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
AMROSAAD
Hey guys, hope you are fine.
For past some days, there is a problem in a car. When my car reaches a speed of around 55-60 mph, there is vibration and shaking, is this due to trouble in transfer of gear from lower level to higher level? Car runs smoothly at other speeds, it has trouble only when the speed is around 55-60 mph. Please advice!
Thank you,
Amro
Dec 24, 2019 at 2:41 PM
It is possible; however, I would start with wheels and tires as I suspect that is what you are dealing with.
By far more vibration like this are due to worn wheels and tires.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
I would suggest with starting with rotating the tires and see if the vibration is better. If the tires are already worn, then you need to replace them and make sure you keep them rotated.
https://www.2carpros.com/articles/how-car-tires-work
Also, please see the chart below that will help with trying to identify tear wear issues.
Please run through all this info and let us know what questions you have. Thanks
Oct 27, 2021 at 11:50 AM
