Gearbox noise
55,000 MILES • 1.4L • MANUAL
CRD67
Hi, my daughter wants to buy a Peugeot 207 Hatchback 1.4 VTI Sport 5DR (2011) but the advert says "on test drive we noticed slight noise from gearbox in low gears , drives really well , very good history with invoices and previous MOTs" is this noise likely to cause her problems and money. Thanks
Mar 24, 2021 at 7:56 AM
BORIS K
  • 836 POSTS
It sounds like that the transmission might require looking at by a specialist workshop for accurate diagnosis.
The most common cause of a noisy transmission is insufficient oil, causing the gears or internal assembly to hum or whir. If a noisy transmission does have enough oil, the lubricant may be contaminated with metal shavings or particles.
Insufficient or contaminated oil may cause the transmission to become noisy in some or all of the gears. But if you hear noises in specific gears, that gear's teeth or synchronizer may be worn or damaged.
Average prices for a good used transmission are around £350 excluding labor and clutch, if a new one is required.
Please let us know if you require any more specific advise
Cheers, Boris
Mar 25, 2021 at 3:18 AM
CRD67
Thank you for your answer. You have saved me a lot of money, I decided not to buy the car! Thank you
Mar 28, 2021 at 1:27 PM
  • 110,251 POSTS
Thanks for letting us know. Always remember the old saying when it comes to buying a car, "Buyer Beware." LOL
Feel free to come back anytime in the future. You are always welcome here.
Mar 31, 2021 at 11:31 AM
