Gear shift will not engage gears
109,000 MILES • 3.9L • 6 CYL • 4WD • AUTOMATIC
RTRUMPOW
I have the V-6 engine, automatic transmission, 4X4. The gear shift will slide out of park, but the indicator remains on park and the gear shift does not engage any gears. I have checked the fuse, the transmission fluids have been changed as well. Aside from a costly repair, is there anything else I can check before having to get my truck towed?
Aug 11, 2016 at 12:13 AM
HMAC300
  • 48,601 POSTS
it may be a harness problem at switch on transmission or the switch is bad, but it should be scanned for codes to find out what if anything electrical is doing it.
Aug 11, 2016 at 1:15 AM
