The gauges will drop to zero, the service vehicle soon, and security lights will turn on?
100,800 MILES
FIGGY&TRIXIE
The odometer and shift indicators work fine though.
Jul 2, 2023 at 3:54 AM
  • 110,251 POSTS
This can be an issue with the instrument cluster, body control module, or a wiring issue. What we need to do is scan the can-bus to see if there are codes specific to this issue.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing it.
Here is a link showing how it is done:
I'm suggesting this because without doing it, the repair will become a guessing game. That can become expensive. If there are codes retrieved, I can help you focus on the problem area identified.
Let me know your thoughts and if you have questions.
Jul 2, 2023 at 2:24 PM
