Car has to turn over a lot before starting in the morning
60,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
EFIL
About two weeks ago I noticed a gas leak when car is being filled. Anything over 3/4 tank leaks out. Nothing new had similar issue with other vehicles.
The question I have is about a week after I noticed the leak, the car had to turn over a lot in the morning before it would start. Almost like it had no gas in the line. Is it a pressurized system that would cause this? Only after leak did car start having problems starting in the morning.
Nov 3, 2016 at 4:20 AM
HMAC300
  • 48,601 POSTS
check for a leaking fuel line or maybe a small hole in top of tank causing the problem . You can check fuel pressure as well see if there is any if very low or none it may be a bad pump or a leaking line/filter. See link.
Dec 14, 2018 at 1:37 AM
