Fuses are blown
163,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SKEEMAN1
I put gas in my car Saturday night and cranked the car up. When I went to put the car in gear to driver it cut off. The battery died out from trying to work on the car with the tow company. I checked the fuses and all of them are blown. What could be the problem. I got it charged up enough but I know it will only shut off again and fuses will blow if I replace them. What could be the problem?
Mar 11, 2019 at 1:13 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, I need to get a better understanding. When you say all the fuses were blown, I have to say that is nearly impossible because they are all associated with different circuits. Which fuses blew? There is a fuse box under the near the battery and one at the end of the of the dash. Also, when this happened, was there any smell associated with it which may indicated an electrical short? Any smoke observed?
Please confirm.
Thanks,
Mar 11, 2019 at 12:44 PM
