Fuse
79 MILES • V8 • AUTOMATIC
ADRIAN VALERIE
I need to know what fuse is to the Windows they don't role up or down
Jul 28, 2017 at 5:42 AM
CARADIODOC
  • 34,417 POSTS
Power window systems rarely use fuses. Being considered a safety system, they are normally protected by auto-resetting thermal circuit breakers. When they trip, they will try to reset within about half a minute to make the system functional, if only for a short time. If all the windows are dead in both directions, a better suspect is broken or frayed wires between the driver's door hinges. One potential clue is the system might work intermittently as you open and close the driver's door.
Jul 28, 2017 at 12:57 PM
