Poor fuel mileage after moving to Arizona from Indiana
88,000 MILES • V6 • 2WD • AUTOMATIC
SHIRL8557
I recently moved from Indiana to Arizona. In Indiana I could get 400 miles on my 16 gallon tank. Now as I have moved to Arizona (Maricopa County) I only get 200 to a tank. I do not do interstate travel. It's mostly just little trips of 5 miles or less. Running the air conditioner which i didn't do in Indiana and also waiting at lights in town which I did not do in Indiana. Some one told me it is due to the fuel quality difference that is doing it. I just want to know if I should let it go or look to a dealer here in Arizona to get my car looked at. I appreciate any information that I could use to make an informed decision. Thank you
Sep 24, 2020 at 3:01 AM
Couple things. First, I would challenge you on the 400 down to 200. A lot of times what we do is generalize our distances. Meaning there may have been times when you went 400 miles on a tank of fuel but there were also times when you did different types of driving and only went 350 miles on a tank. Then I understand you feel like you are only going 200 miles on a tank now but there are times you go 250 miles. So in general there is a difference between the two but it may not be cut in half. That sounds a little drastic. So let's write down the mileage at the next fill up and see what it is when you fill up again and how much is left in the tank.
The other idea that the fuel quality is lower is not true. I assume they are talking about octane levels. This is not a rating in quality. This is a rating on the ability to combust in the engine without causing spark knock. So the higher the altitude the lower the octane rating needs to be to achieve this. So you actually get better fuel mileage in higher elevations but lower performance.
Lastly, if you are driving in short distances and stop and go traffic, that is when you get the worst fuel mileage. If you think about it, your miles per gallon is figured by how much distance you travel per gallon used. So if you are not driving far and idling a lot then your distance is not going to be far. If you are driving much different, I would not worry about the distance per tank but look at your fuel cost per month. I would expect your fuel cost to be about the same or a little better if you are not driving as far in AZ.
Does that make sense?
Sep 24, 2020 at 3:44 AM
SHIRL8557
Thanks KASEKENNY1, but I do have a mileage meter in my car that beeps when I get to 50 miles to empty, and it keeps pretty good track of how many miles I drive between fill ups and the 400 to 200 is pretty accurate that's what concerns me. I figured it was because of A/C usage and short distances and stop and go, but just thought it a little strange that there is that drastic of a change in efficiency. Thanks for your input.
Sep 24, 2020 at 6:20 AM
SHIRL8557
I do understand what you are saying about mileage though not being true because you are running the engine and burning fuel and yes I am getting a greater length of time between fill ups because i don't go as far or fast. I appreciate your input.
Sep 24, 2020 at 6:25 AM
Okay. That is good to know. So I think you are correct that driving style and adding the A/C will account for the drop. It does seem a little much but if you are going longer between fill ups then I suspect it is accurate. Thanks for the update.
Sep 24, 2020 at 12:16 PM
