fuel uplift pump
25,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
OLIVIA83
A garage has fitted a diesel fuel uplift pump to my petrol car. Now the car makes a horrible noise has lost power and dumped two liters of oil somewhere. Is this even possible to do? And what do I need to say to them to fix it ?
Many thanks.
Nov 29, 2017 at 5:15 PM
  • 31,937 POSTS
I would be getting them to fit the correct fuel pump. if indeed you can fit a diesel fuel pump the pressures would probably be different. as for the oil loss, it can only burn oil or lose it externally. do you have any external leaks?
Nov 29, 2017 at 6:24 PM
