Codes P0087 and P053F, Fuel system repair help needed?
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOSEPH.P23
Very poor acceleration, fluctuating RPMs up and down, shakes at highway speeds of 70+ MPH, very reduced power. Code reader gave, P0087, P053F, since then I have replaced high pressure fuel pump, upstream and downstream oxygen sensors, recently ran a complete fuel system fuel additive and currently running a fuel injector cleaner fuel additive as of today 8/19/24. Asking for help of what could be the issue after replacing said parts and adding fuel additives?
Aug 19, 2024 at 11:21 AM
BORIS K
  • 836 POSTS
P0087 - fuel pressure too low
P053F - fuel pressure too low on start
The fuel delivery system is made up of the low-pressure pre-delivery system, comprising of an in-tank fuel pump and fuel filter. the high-pressure fuel system comprises of the high-pressure fuel pump and the fuel rail with direct injection injectors and fuel rail pressure sensor connected
The in-tank fuel pump will deliver fuel from the tank to the high-pressure fuel pump. The low-pressure system should supply fuel at about 5bar/73 Psi. This can be checked using a fuel pressure gauge connected to the supply line to the high-pressure pump
How to:
If the pre-supply pressure is correct then next the high-pressure pump is either not generating enough pressure, faulty pump or mechanical issue with the activation from the cam follower or worn camshaft. If the mechanical side is in order, we could have an issue with the rail pressure sensor not reading correctly. With ignition on/engine off the rail pressure sensor should read the in-tank fuel pump pre delivery pressure. This can be verified using a suitable diagnostic scan tool which can read live data from the ECM.
A video:
https://youtu.be/lF4BSTl_S5w?si=KRieqorjMEbkQaxd
The rail pressure sensor is located in the fuel rail underneath the intake manifold
You will need to remove the manifold to gain access
A video:
https://youtu.be/LVPvdiYDRh4?si=UezVBBa6CGqrbRtY
Hope this helps.
Cheers, Boris
Aug 19, 2024 at 9:01 PM
