LPG system removal instructions needed
2009 FORD FALCON
200,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MHIGGV8
What is involved in removing LPG system in a Ford vehicle factory system. is it cheaper to buy a wreck or buy new parts? the area I live in only has one LPG outlet.
Feb 23, 2021 at 2:17 PM
Unfortunately we don't have a manual or instructions on how to remove this system but the idea is simpler than actually doing it.
Once you close the valve on the tank (propane vehicles should all have an isolation valve) you will be able to start removing all the components, just be aware that their may still be some pressure when you open the system.
As for what parts you should get, the cheaper way to go is to get used parts off a wrecked car so I would go that way if I were you.
Sorry we can't provide specifics on how to remove these components but let us know what questions you have and we will do what we can to assist. Thanks
Feb 24, 2021 at 5:52 PM
