Where is my fuel pump relay located?
62,000 MILES • 4 CYL • 2WD • AUTOMATIC
WESH977
Fuel pump relay location. I had been driving my car every day for the past 2 years. Then in the past 2 weeks I started driving a company vehicle. Then on the weekend I went to start my vehicle, and it would crank over but not start. I watched some videos of others with the same issue, and it turned out to be the relay. Now I would like to locate it to change it. Thank you for any help and it would be greatly appreciated.
Mar 22, 2025 at 3:54 AM
STEVE W.
  • 15,404 POSTS
Well the relay is in the smart fuse box under the hood on the left side. Pump power comes through fuse 48. However, I suspect it isn't the issue. What I commonly find in a situation of a vehicle being driven, then parked and having a problem is rodent damage. The vehicle sets long enough that they make it a home and will chew on the wiring. As such the first thing I would do is open the hood and look around areas that the wiring runs and look for droppings and damage.
Mar 22, 2025 at 2:31 PM
