Engine shut off at a stoplight
172,000 MILES
ROBERT GOSS
Towed it home I found that the pump was not getting power. I went straight to the battery the pump came on. When I crank it over it turns faster than normal making me think it might be the timing belt it was changed less than 40,000 miles ago. I took a peek inside. The belt is still going around the pulley. I've checked all fuses. Also switch to relays still nothing.
Jun 9, 2022 at 6:43 AM
If this engine cranks faster than normal then that is a sign of no or low compression.
So, let's start right there.
Here is a guide that will help with checking the compression but let's check it on a couple cylinders just to be sure. However, if the first one you check is zero then we know what the issue is.
https://www.2carpros.com/articles/symptoms-of-low-compression
Just because the belt is still on the pulley doesn't mean that it isn't stripped or there is a pulley issue.
So, let's start with this and go from there.
Thanks
Jun 10, 2022 at 12:37 PM
