Can I attach the electrical housing from the fuel pump to the ground wire from the fuel pump directly to the chassis?
1992 CHEVROLET 1500
160,000 MILES
BFBRACY@GMAIL.COM
The ground wire was on top, and the electrical housing was underneath it attached by a screw cannot get it to attached now.
Aug 13, 2023 at 5:54 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
If I understand you correctly you can. You mean you want to ground the fuel pump module to the frame, correct? If so, you should be okay.
Aug 14, 2023 at 1:06 PM
