Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
1500
Engine
Wiring
Can I attach the electrical housing from the fuel pump to the ground wire from the fuel pump directly to the chassis?
1992 CHEVROLET 1500
160,000 MILES
BFBRACY@GMAIL.COM
MEMBER
1 POST
FOLLOW
The ground wire was on top, and the electrical housing was underneath it attached by a screw cannot get it to attached now.
Aug 13, 2023 at 5:54 AM
CERTIFIED EXPERT
If I understand you correctly you can. You mean you want to ground the fuel pump module to the frame, correct? If so, you should be okay.
Aug 14, 2023 at 1:06 PM
