Fuel problem
78,795 MILES • 5.7L • V8 • 2WD • MANUAL
SCH PETE
  • 6 POSTS
OK I just rebuilt the motor in my 76 Chevy C20 and now I am not getting fuel to my pump can anyone help me out
Aug 11, 2016 at 10:16 AM
CJ MEDEVAC
  • 11,000 POSTS
Been running or sitting forever?
Sock in tank stooped up?
Loose hose connections at tank or pump?
Hole in suction line from tank?
Is suction hose connected to correct pipe into tank (if there is a return line to tank)
Fuel pump is good?
Have you checked for fuel just before it reaches the carburetor?
As a "feel good", connect a short rubber fuel line from the fuel pump suction connection and drop the other end into a fuel can. Does this work?
Return with news
The Medic
Aug 11, 2016 at 11:06 AM
SCH PETE
  • 6 POSTS
Hey sorry it has taken a while to get back to you OK yes it has been sitting a little while but I have had it running and there are no loose hose connections and they are all connected to the right lines and fuel pump is good and I did put a hose in a gas can and it will pump so the only thing I don't know about is the sock in the tank and a friend said it shouldn't be that so I am not sure what to do so any help I get would be very helpful thanks
Aug 14, 2016 at 7:21 AM
  • 55,710 POSTS
Did you install the push rod to the fuel pump when you reassembled it?
Best, Ken
Aug 15, 2016 at 4:59 AM
CJ MEDEVAC
  • 11,000 POSTS
So it does pick up fuel from the test fuel can!
Move your fuel can near the fuel tank.
Snatch the fuel line loose at the tank and extend it to the fuel can. (you may need one of those brass barbed couplings to join the end of the fuel system to your extension hose to the can)
This will test the line all the way to the tank.
If it won't pick up, there's a hole or crimp in the line somewhere.
If it does pick up, it's gotta be in the fuel tank.
I reckon maybe you already understand all of that!
Keep us posted
We are pulling for you!
The Medic
Aug 15, 2016 at 10:27 AM
SCH PETE
  • 6 POSTS
OK I will try that and let you know thanks and yes I did put the push rod back
Aug 15, 2016 at 10:32 AM
SCH PETE
  • 6 POSTS
OK I'm back and it is running now it was sucking air at my fuel filter that was the problem so thank all of you and thank you CJ for your advice it really helped thanks again
Aug 15, 2016 at 11:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Wonderful!
I thought I heard some hissing!
Next time you see "Mr. Jeep" or "Willy"running down the road, run me down, you can buy me lunch!
Let's see a pic of your truck, We've all been sorta blindly working on it!
Do return to see us, bring your buddies along too!
The Medic
Aug 15, 2016 at 11:59 AM
  • 55,710 POSTS
Nice work everyone, like to see that we help fix problem here at 2CarPros, please come back anytime we are here to help.
Best, Ken
Aug 16, 2016 at 12:52 AM
