Intermittent issue of spitting, sputtering and shutting off
176,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
BRITTANY PARKER
Sometimes the truck runs fine and other days it act like is starves for fuel will cut out, spit and sputter and sometimes shuts off. sometimes wont but runs really bad. Has the fas fuel. We have change the filter, ECM everything and it is still doing the same thing. We don't know what else it could be. Also sometimes the check engine light will come on and he will get codes about failure to communicate to the computer.
Oct 6, 2020 at 10:12 PM
Good morning,
Can I have the code numbers? I need them to help.
As far as the engine, I would check the fuel pressure to be sure you do not have a bad fuel pump.
https://www.2carpros.com/articles/engine-hesitates
https://www.2carpros.com/articles/engine-has-low-power-output
Oct 6, 2020 at 10:54 PM
