Runs fine then sputters and shuts off
JUDY CHAMLEE
  • 1993 BUICK CENTURY
  • 1.2L
  • V8
  • 10,000 MILES
Runs fine then sputters and cuts off. Let it and it will run good then cut off again.
Monday, January 1st, 2018 AT 3:13 AM
  • 52,797 POSTS
Good morning.
The most common issue for this failure is the ignition module. You can remove it and have it tested for free at a parts store to verify it has failed.
A crankshaft position sensor is another common failure.
When it stalls, does it start right back up or is it extended crank?
Monday, January 1st, 2018 AT 4:17 AM
