Fuel
93,724 MILES • 3.8L • 6 CYL
RICKY BREAUX
Engine is flooded with gas.
Nov 13, 2017 at 4:15 AM
CARADIODOC
  • 34,414 POSTS
Change the oil and filter right away to get the gas out of the oil. The most likely cause is a leaking fuel pressure regulator. That will allow gas to be sucked into the vacuum hose, then it will overload the piston rings and wash past them into the oil.
Nov 13, 2017 at 8:38 AM
RICKY BREAUX
Thank you. That is what I was thinking just wanted to make sure.
Nov 13, 2017 at 11:48 AM
