Lost all gauges and lights at the front dutch panel
1997 FORD F-150
200 MILES • 6 CYL • 2WD
GEMMA44_98YAHOO.COM
Only engine check and battery lights are working. I checked all fuses and sims they are okay . Question, could be a relay? but i don't know which one? Thanks in advance for your help and cooperation. Best regards
Jul 6, 2019 at 9:33 AM
  • CERTIFIED EXPERT
Hi Gemma44
Unfortunately the way your gauges and lighting works is they are contained in the cluster. Each gauge gets a signal directly from the sensor so to have all of them out, the only common denominator is the cluster.
There are no relays for the cluster so based on this information, I would put a cluster in it. Let me know if you need more information. Thanks
Jul 7, 2019 at 6:58 PM
