There is a noise coming from the front driveshaft area. There is some play in the front differential output to shaft. I want to remove the front driveshaft and use my vehicle while the parts are coming in. Is there anything I need to do after the driveshaft has been removed or can I just drive it in two wheel drive or will it leak oil out the front?
Sep 10, 2018 at 7:12 AM
