1983 Ford Truck Dies at Idle
NATHANTRUCK
i have a 1983 ford truck 302. my truck is not running at the moment. when i start the truck it will stay on as long as i keep my foot on the gas pedal then when i remove my foot the truck will shut off. sometimes the truck will stay running even when i remove my foot but, as soon as i try to put it in drive it will die. so my question is what would cause this and can i do it myself?
Aug 10, 2006 at 4:46 AM
SYNCRAIT
  • 235 POSTS
it could be just about anything but i would first start with the basics....replace the plugs and do a basic tune up if that dosent help much check all your vacuum lines and make sure they are all connected and none are torn lemme know good luck :)
Aug 10, 2006 at 6:44 AM
Suggested Repair
Replace the spark plugs and perform a basic tune-up. If the stalling continues, inspect all vacuum lines for disconnection or damage.
Conversation Summary
The owner of a 1983 Ford truck with a 302 says it stalls when the foot is removed from the gas pedal and sometimes dies when shifted into drive. The expert suggests starting with a basic tune-up and new plugs, then checking vacuum lines for leaks or disconnection.
