Sure sounds like the p/s pump. Fords are notorious for loud pumps, if the fluid level is ok, try removing some of the fluid and adding about 3-4 tbsp's of motor oil. This will sometimes quiet them down. If not it may need a new pump, but if you go with anything other than OEM (motorcraft) you may wind up with more noise than when you started
SPONSORED LINKS
Monday, June 9th, 2008 AT 12:08 PM
