Does it use coolant with no visible leaks? It could be an injector problem or even worst case a head gasket that is leaking a little coolant into a cylinder overnight, that is why I asked about the coolant loss. When they did they did the plugs, they may have noticed one that was lighter in color than the rest, this would indicate a weak injector or head gasket. You can have a chemical test done to see if there is any exhaust present in the cooling system (head gasket) the test isnt 100%, but it is close
SPONSORED LINKS
Wednesday, June 9th, 2010 AT 8:43 PM
