Number 6 cylinder misfiring
SILVERSEL
  • 2001 FORD WINDSTAR
Engine Performance problem 6 cyl Front Wheel Drive Automatic 122000 miles
Had engine code P0306, which is #6 cylinder misfiring. Replaced plug and lead, also checked fuel injector for clicking sound which means it is working. I am wondering if coil is bad in cap.
Sunday, February 22nd, 2009 AT 3:58 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
I would do a compression test to see whats going on. Here is a guide
Please run this test and get back to us.
Cheers, Ken
Sunday, February 22nd, 2009 AT 7:45 PM
SILVERSEL
I did replace the plug and wire. There is only one ignition coil for all six cylinders.
Monday, February 23rd, 2009 AT 8:59 AM
  • 109,885 POSTS
If you replaced the plug, wire, and you hear the injector working, you need to check compression in that cylinder. As far as the coil, I would think a bad one would create a random misfire and not only cyl 6.
Let me know what you find. Also, make sure there are no vacuum leaks.
Monday, February 23rd, 2009 AT 9:09 AM
SILVERSEL
Ford car dealer found broken valve spring on #6 cylinder. Van runs fine now. I was glad to see that it was only a broken valve spring and nothing major. I appreciate all the help and maybe this will help someone else with a like problem. $280.00 all fixed
Tuesday, February 24th, 2009 AT 8:18 AM
