Air Conditioning problem
2001 Ford Windstar 6 cyl Front Wheel Drive 135000 miles
When I engage the AC the engine stalls at low idle speeds. Also, the compressor makes a grinding noise even when not engaged. Occasionaly there is smoke comming from the compressor pully.
Last night the van would not turn over at all. Either by coinsidence the starter relay may have went out or the compressor is preventing the engine from turning over.
Is the not starting due to the compressor or could it be something else?
Apr 14, 2010 at 3:38 AM
