2001 Ford Windstar engine hesitation
C3DADDYO
Engine Performance problem
2001 Ford Windstar Front Wheel Drive 93650 miles
The engine of the Windstar will stall, pop, sometimes backfire. At first I thought it was water in the gas. Wife put something in tank to fix that. But as driving, it seems to get worse when going up hills or trying to maintain a steady speed. When going up a hill, you push on the gas, brief pause, then the vehicle lunges. Had a diagnotics done and the mechanic said it was misfiring. What could be causing this? With what I have found in my search is that it could be anything from a failing spark plug to the timing belt needing replaced. Any ideas? Can I fix this on my own?
Feb 19, 2010 at 1:04 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 19, 2010 at 9:24 AM
