My van and it would not roll over
GYPSYCLAGG
  • 2000 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 185,000 MILES
I had parked my van in the drive way after driving 3 hours, I went out the next morning to start my van and it would not roll over let alone start so I checked the battery and it is fine even hooked up a jump start battry box to the van and tried to start it that way but still nothing happened. COuld you please give me some advice on what could be wrong with my van.
Monday, October 4th, 2010 AT 1:59 PM
JDL
  • 16,098 POSTS
What about your security system? I'd have to check the circuits at the starter relay. Terminal 30 is hot all the time. Terminal 86 goes hot with the key in the crank position. Terminal 85 is ground for the coil side of relay. If the problem is the security system, the ground may be affected? Any testing, make sure the tranny is in park or neutral and the e-brake is set.
https://www.2carpros.com/forum/automotive_pictures/170934_windstar_starter_circuit_1.jpg
Tuesday, April 6th, 2021 AT 7:13 PM
