HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Windstar
Engine
Symptoms
Idle Rough
2000 Ford Windstar ROUGH IDLE AND DIES WHEN IN DRIVE
MTBBIC
MEMBER
2000 FORD WINDSTAR
Engine problem
2000 Ford Windstar V6 Front Wheel Drive Automatic 95000 miles
IT HAS ROUGH IDLE AND DIES WHEN IN DRIVE
Wednesday, December 5th, 2007 AT 8:20 PM
BMRFIXIT
MECHANIC
When was your last tune up?
Check the intake manifold for vacuum leak
SPONSORED LINKS
Wednesday, December 5th, 2007 AT 10:19 PM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
Rough Idle When Engine Is Warm With Automatic...
Rough Idle When Engine Is Warm With Automatic Transmission In Park. Smooths Out When Transmission Is Shifted Into Either Reverse Or Drive....
Asked by
RLBjr
2000
FORD WINDSTAR
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
2000 Ford Windstar Cutting Out On Acceleration
When I Accelerate Hard (for Getting On The Hiway), Pedal Down Less Than Half Way, When The Engine Rpms Get To About 2800, The Engine...
Asked by
ultrabuzzard
1 ANSWER
2000
FORD WINDSTAR
1999 Ford Windstar Rough Idle And Heat Up
Engine Problem 6 Cyl Front Wheel Drive Automatic 116000 Miles Engine Ok Most Of The Time, But, After Engine Reaches Max Temp; Say And...
Asked by
dgoldenberg1213
1 ANSWER
1999
FORD WINDSTAR
2003 Ford Windstar Rough Idle
When Starting My Car: It Starts Fine, Then Quickly Goes To A Rough Idle, Bucks, And Dies Out. This Happens At Every Stop Also. Drives...
Asked by
jillcuttone
2003
FORD WINDSTAR
1995 Ford Windstar Rough Idle
Engine Performance Problem 1995 Ford Windstar 6 Cyl Front Wheel Drive 148000 Miles Hello There Some Weeks Ago There Was An Issue With...
Asked by
rgrandam1
1 ANSWER
1995
FORD WINDSTAR
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
Online car repair manuals
