Is this a possible dead spot on the starter
JERRY WOLF
  • 1996 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 115,000 MILES
When I tried to start the car, it sounded like it was just beginning to start and then nothing, after doing this approx 15 times it started. Could this have been a dead spot ont he starter?
Also not every time but once in a while when the engine first starts there is white vapor from the taiilpipe. This may go on for one to two minutes and then stop. I am not losing fuids, so it is not antifreeze burning. The engine is running okay when this happens.
Any idea?
Tuesday, May 26th, 2009 AT 2:42 PM
*** if its cranking over then start dragging slowly/nothing and engine not turning sounds more likethe overrunning clutch in the starter is slipping the fix is to replace it.
*** Its probably just condensation if its not leaking and overheating
Tuesday, May 26th, 2009 AT 3:11 PM
