Engine Performance problem
1965 Ford Truck V8 Two Wheel Drive Automatic
I have a 65' ford 351 Windsor engine that has been sitting for about a year now. I got it running, rebuilt the 600 Holley, set the timing where the previous owner had the marks on the balancer( 4-6 bdc I believe) drained the old fuel out and put fresh in. It starts right up, got it to idle ok, but when I gas on it, it seems to run ok but it pings quite a bit. Tried adjusting the timing out on the road and it either runs poorly or it will die when I gas it. I don't know much about the specs on the engine as thr guy told me it was a Cleveland, checked it out and it is a Windsor. Any suggestions would be very helpful. It has the stock distributor setup with vac. advance which seems to be working. Thank's, Tim
Apr 18, 2009 at 3:36 AM
