2002 Ford Thunderbird Heater Blows Cold
TJBTJBD
Heater: As you know, the heater setting moves degree by degree up to 85, then the next increase available is all the way to 90. At 85 degrees or less, it blows only unwarmed air. Actually, for a couple of minutes, sometimes, it will blow warmed air. However, if I go all the way to 90, it blows warm air just fine. Can you help me understand my problem and how I need to proceed. Please note I did make a donation already.
Thank you very much.
Thomas
Nov 27, 2007 at 3:41 AM
MERLIN2021
  • 17,250 POSTS
Ok I do see the donation, Thank you for that!
Now turn the ignition key to on, then at the same time press the floor and off buttons on the heater, then quickly press auto, if a number comes up in the display, post it for me, and I will tell you the problem...25 is the one I suspect.
Nov 27, 2007 at 4:45 AM
TJBTJBD
Thank you, Merlin.
When I did as you said, first came zero on the left side and 25 on the right, then it proceeded through 1 and 24 (left and right), then 2 and 23, then 3 and 22, etc., and ended with 25 on the left and zero on the right.
I eagerly await your reply.
Regards.
Thomas
Nov 27, 2007 at 6:53 AM
MERLIN2021
  • 17,250 POSTS
Ok from here just to eliminate the heater core, warm the engine, then feel the two heater hoses going into the firewall, they BOTH should be real hot! So be careful, if one is cool or cold, the heater core is clogged and will need flushing, or replacing. If the hoses test OK, 25 comes up as the blend door actuator. It's an electrical motor that psitions the door as you move your thermostat, Do you hear any clicking under the dash when you adjust the thermostat?
Nov 28, 2007 at 6:47 AM
Suggested Repair
Warm the engine and carefully feel both heater hoses at the firewall; both should be very hot. If one is cool or cold, flush or replace the clogged heater core. If both hoses are hot, climate code 25 indicates the blend door actuator; listen for clicking under the dash when changing the temperature setting.
Conversation Summary
The owner of a 2002 Ford Thunderbird said the heater blows only briefly warmed or cold air at 85 degrees or below, but heats normally at 90. After a climate self-test that displayed code 25, the expert advised checking both heater hoses to rule out a clogged heater core and, if they are hot, suspecting the blend door actuator.
