1995 Ford Thunderbird White Exhaust
DEFAULT_USER
Hello, I own a 1995 Ford Thunderbird LX V8 4.6L
I recently drove down from Sacramento California, to San Francisco, on my way there, my check engine light came on, unfortunately, I was in no position to pull over, or stop. And everything seemed fine, no power loss, leaks, or anything suspicious.
Now, 3 weeks later, I have found that i'm having excess exhaust, color = white.
Every question previous to mine seemed to have other weird things going on, so I think I needed to ask for myself.
I haven’t gone to a mechanic yet, I was wondering if anyone could point me in a more directed area of diagnosis
Jul 23, 2006 at 12:56 AM
TAURUSWHEEL
  • 718 POSTS
How many mile??? If it's definately white, it's coolant,, added any lately to your radiator???,, give the exhaust a sniff, you'll most likely be able to smell the coolant... headgasket is probably blown,, check engine light could be anything, o2 sensor could have been coated with antifreeze, right now I would recommend calling a reliable repair shop, if you have one, if not call the local Ford dealer, tell them you want a leakdown test done, they'll know what to do, will confirm a headgasket issue... I would get it done asap, you don't want coolant somehow finding it's way into other areas, it'll trash your engine pretty quick.. I'm thinking I read something somewhere about gasket issues with these motors, not 100% on it though
Jul 23, 2006 at 3:20 AM
Suggested Repair
Have a shop or Ford dealer perform a leakdown test to confirm a suspected head gasket leak. Check the coolant level and smell the exhaust for coolant, and address it promptly so coolant does not damage the engine. The check engine light could involve an oxygen sensor coated by antifreeze or another cause.
Conversation Summary
The owner of a 1995 Ford Thunderbird reported a check engine light with no power loss or other symptoms, followed three weeks later by excess white exhaust. The expert said white exhaust usually indicates coolant and a likely blown head gasket, and recommended a leakdown test as soon as possible.
