1997 Ford Thunderbird Extremely high engine idle after batt
1997 FORD THUNDERBIRD
163,000 MILES • V8 • 2WD • AUTOMATIC
JACKIE8516
We replaced the battery in our 1997 Ford Thuderbird. Now the enging idles at 1500 rpm in the park position. I have read about the re-learn process for the idle, but do not understand. We have driven the car for at least 30 minutes and the engine idle does not change to a regular idle. Is something else wrong? We are afraid of the effect on the transmission.
Apr 14, 2009 at 6:59 AM
Do you have a CEL? Do the relearning process -if it continues check the idle air control valve
Apr 14, 2009 at 9:10 AM
JACKIE8516
We disconnected the battery cables and re-connected them and that solved the problem.
Thanks
Apr 15, 2009 at 6:15 AM
