1997 Ford Thunderbird CODE P1443
JAMALL
Computer problem
1997 Ford Thunderbird V8 Two Wheel Drive Automatic
WHAT CAN BE THE PROBABLE CAUSE FOR CODE 1443
May 14, 2010 at 11:23 AM
  • 110,248 POSTS
There are a few:
Possible Causes:
- Pinched, blocked or plugged fuel vapor tubes/hoses
- Damaged EVAP canister
- Disconnected, cracked or cut fuel vapor tubes/hoses
- Damaged EVAP canister purge valve
WIth the engine running, open the hood and listen for a hissing sound that could indicate a leak. Also, check for fuel smell in the engine compartment or near the EVAP canister.
May 15, 2010 at 3:35 PM
