1997 Ford Thunderbird car sutters and wants to die when put
1997 FORD THUNDERBIRD
BBB
Transmission problem
1997 Ford Thunderbird V8 Two Wheel Drive Automatic
with car in overdrive mode. i put car in reverse it sputters and wants to die and has several times. then i put it into drive and it sputters and gerks a bit. when i start to slow down when approaching a stop light the car wants to die. I have to put it in neutral and give it some gas. had the transmission rebuilt about 6 months ago. I pushed the button that turns off the overdrive and car runs fine. The check engine light has been on for awhile.
Feb 13, 2008 at 12:13 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like you have a problem with the torque converter clutch solenoid in the transmission. this is a relatively easy fix. you need to drop the pan and replace the solenoid, or bring it back to the tranny guy, he will probably hook you up. hope this helps
Feb 13, 2008 at 12:28 PM
