I replaced my rear pads and rotors due to normal wear. I bled all four calipers, using up a quart of regular dot 3 fluid and have a full fluid reservior. Whether the car is on or off, the first time I hit the pedal it goes to the floor with hardly any resistance. I have to pump the pedal to get it to brake, but then the pedal gets really hard to push. When the car is running and I'm holding the pedal, there is a hissing sound coming from the firewall. During a test drive I have to stand on the pedal to keep the car from rolling when it is stopped. Do you think it is air in the system or a jammed caliper piston,.....or.....?
Oct 18, 2009 at 9:19 AM
