1986 Ford Thunderbird EFE Valve
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
JESSELEE
How do I replace my EFE Valve? How much would it cost to have done by a mechanic?
Thanks
Feb 23, 2008 at 11:23 AM
  • 75,988 POSTS
The EFE valve could be the Bimetal or vacuum operated its called the heat control valve/heat riser to preheat the incoming air-to the intake manifold Its take an 1hr to replace it-ranges from $70-$130.00 per hr. labor rate not including part/s shop around for a better deal.
https://images.2carpros.com/forum/automotive_pictures/12900_heat_riser_1.jpg
Feb 23, 2008 at 11:41 AM
