After doing 100km on highway, all went well. The car was running well, idle when parked and i turn it off. About 2 mins after, i fired it back up and start right away but the idling was real bad ! Like if there were not enough fuel or fire was too weak! After like 5 sec of bad idling i decided to turn it off. Turn back on and it start but idle again bad, i tried giving gas, no change than after another 5 sec, it died. Tried to start it up again, engine was cranking okay and fast enough like normal but will not start.
I unplug the fuel filter, the side going to the engine and saw fuel pressure was present, so i plug it back in...
the reason why i am thinking it's fuel related is like for 2 months, when i turn the key to ON position, i can hear a bubling sound coming from where i think is in the tank. Sounds like the fuel pump. The fuel pump have been changed about 3 months ago so i don't think it's related with the pump itself.
I can remember that yesterday before starting the car, i can only hear the Tick which the fuel pump does before cranking the engine, i didn't hear the 3 seconds buzzing sound or bubling sound. (because sometimes it does the buzzing sound and sometimes, more often lately, the bubling sound)
What can i check for issu ? Can the fuel pump relay do that ? Fuel pressure regulator ?
Oh yeah...by the way, later that night i tried the car for the heck of it and it started ! So i was able to go home, but didn't stop the car before arriving home. This morning i started the car to go work and all is good...
Someone having an idea what's wrong or what to check ?
I will get myself a fuel pressure gauge pretty soon, i will have something to check if that happen again soon...
Dan
Dan
Nov 9, 2009 at 3:11 AM
