1993 Ford Tempo Brake problem
1993 FORD TEMPO
110,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVENWALZ
I have a 93 ford tempo, the brakes are not working properly. The peddle goes to the floor. I replaced the master cylinder, a front caliper, front pads, rear shoes and rear wheel cylinders. I have bled the brakes multiple times and still have no peddle. It will stop when pushed to the floor. What else could be wrong. Please help
Apr 21, 2008 at 2:39 PM
MOPARNUT1393
  • 34 POSTS
[quote:ae07a7f730="stevenwalz"]Brakes problem
1993 Ford Tempo 6 cyl Front Wheel Drive Automatic 110000 miles
I have a 93 ford tempo, the brakes are not working properly. The peddle goes to the floor. I replaced the master cylinder, a front caliper, front pads, rear shoes and rear wheel cylinders. I have bled the brakes multiple times and still have no peddle. It will stop when pushed to the floor. What else could be wrong. Please help[/quote:ae07a7f730]
check your master cylinder again...
did you bench bleed the master before you put it in the car? thats where id start ive had masters cylinders that have had an air lock even after bleeding at the calipers.
Apr 21, 2008 at 2:45 PM
