Engine Mechanical problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic
my car has started to idle high, even after it is warmed up
Monday, February 15th, 2010 AT 3:23 AM
FIXITMR
MECHANIC
Could be sticking throttle/pedal linkage/cable or broken/cracked vacuum hose leak or the IAC which is pretty notorious for this effect. May just need cleaning including the electrical plug. If cleaning fails replace it.
