1990 Ford Tempo
TDODDS
  • 1990 FORD TEMPO
  • 4 CYL
  • FWD
  • 122,000 MILES
When going around corners it shakes pretty bad, shakes a little while going straight too but more noticable going around corners
Sunday, October 3rd, 2010 AT 11:35 PM
FIXITMR
  • 9,990 POSTS
Bent/loose wheel or bad tire? Bad axle? Bad wheel bearing? Bad tie rods? I take it you mean steering wheel shakes? When did this start happening? Was it sudden? Also pull on tires from top /sides while not running in park. There should be no play. You can also jack tire up to spin by hand to look for bad tire not round, or wheel wobble.
Monday, October 4th, 2010 AT 1:57 PM
Related General Content
