The way I was able to reach the belt tensioner was, first I put a bottle jack under the engine. Then I removed the passenger side motor mount and jacked the engine up until I could reach the tensioner mounting bolts. After that just put everything back together the same way it came off. There may be a better way to do this, but with the limited room that was available it was the easiest way for me. Also, to remove the motor mount there is a bolt underneath it. You can access this by romoving the passenger side tire, and look up between the motor and the wheel well. It is an 18 mm nut that has to come off.
Jul 28, 2010 at 1:11 AM
