1996 Ford Taurus No Shift Speedometer
RADJE00
i have a 1996 taurus lx that i bought from an auction, i have a transmission problem. my transmission is not shifting and my speedometer is not working. my ANTI-THEFT light on the dash is on.A light on the dash for the doors is on too. i just got off the phone with a shop and they said that it could be a shift solenoid. i was trying to see can u tell me the problem.
Mar 6, 2007 at 3:58 AM
TAURUSWHEEL
  • 718 POSTS
I don't know, I've never bought a car at an auction, did you test this car before you bid on it??? Could be a speed sensor, or it could be something bigger, anti theft light could be problems within the alarm system, door ajar light is probably a sticking door switch somewhere.. I suggest you take it to a local reliable non-major trans shop for diagnosis, some will do it for free, they can scan for trans codes, run some air pressure tests to check solenoid physical operation and such
Mar 6, 2007 at 8:55 AM
Suggested Repair
Have a non-dealer transmission shop diagnose it: scan for transmission codes and pressure-test the solenoids. Also check the vehicle speed sensor, the anti-theft/alarm system, and a sticking door switch for the door-ajar light.
Conversation Summary
A 1996 Ford Taurus bought at auction will not shift, the speedometer does not work, and the anti-theft and door lights are on. A shop suggested a shift solenoid. The expert said it could be a speed sensor or a larger transmission issue, with the anti-theft light possibly related to the alarm and the door light to a sticking switch, and recommended a transmission shop scan and solenoid tests.
