1997 Ford Taurus Spare Key Programming
PHILBERT1998
  • 8 POSTS
97 3.0 Taurus LX.I want to get a spare key.
Does it take a special key or can I get one at the hardware?I read somewhere that the keys have to be "programed".Is it so?
Nov 1, 2007 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
That depends on if you have a blinking red light on the dash? if no light, you don't need a special key, If there is a red light, the keys cost about 50.00 and the proceedure to program the keys is in the owners manual. If you need to know how, let me know how many keys you have now! 2 original keys or already programed keys are needed!
Nov 1, 2007 at 7:00 AM
Suggested Repair
Check for a blinking red light on the dash. If there is none, a standard hardware-store key is fine. If the light is present, a programmed key is required (about $50); the procedure is in the owner's manual and needs two original or already programmed keys.
Conversation Summary
The owner of a 1997 Ford Taurus 3.0 LX wants a spare ignition key and asks whether it must be a special programmed key. The expert says it depends on a blinking red dash light: no light means a regular key works, while a red light means programmed keys are required, with the procedure in the owner's manual and two original or already programmed keys needed.
