I have a 2000 ford taurus se, the problem im having is with the ac system. I have check freon and (about 65 psi) system seems to be fully charged and all fuses have been replaced. The system is continually blowing ambient air. Well since that has started when the car gets up to about 45 mph (with no ac running) its almost like the gears are strugglin until I give it a little gas and then it takes off fine. Are the two problems associated? What are you opinions on this problem?
SPONSORED LINKS
Tuesday, April 18th, 2006 AT 9:47 AM
