I have a used Ford Taurus 2001SES 50k miles. Before I replaced all brake pads and shoes,the front right pad and rear left shoe were worn out extremely.After I replaced all of them (even the master cylinder),I feel vibration on the front passenger's side. The car is front-wheel driving.When I use Jackstand to raise the front and shift it to overdrive after starting it,the front left wheel rotates faster than the front right one.Later on the front right wheel gets jammed.Also the ABS lamp is on but it becomes off when I drive the car. Is this problem associated with failure of the speed sensor on the front right side or with the failure of the hydraulic control system?
thanks for any response.
Jun 29, 2007 at 8:35 PM
